Hi,
I am doing up a 1981 z650
I have a couple of problems and was wondering if anyone can help.
I have a leak coming from the gear selector shaft and it looks like the seal is knackered the clutch push-rod oil seal is also leaking. Any tips or hints on doing the job would be appreciated.
The neutral light does not work. I have tested the wiring and that seems ok. I think it is probably the switch, but I am not sure how to test it.
z650 neutral light switch
