carbs
paulmceleney
- Chunks
carbs
can anyone help took my z900a4 for a ride today i have changed the main jets i have fitted k&n fillters ,iam using 28mm carbs and it has a harris 4into1 fitted apart from this the engine is standard .now the problem is when between 3 4 rpm its start to miss and after 4 rpm it runs fine and below 3 its okay it ticks over fine 1200 rpm thanks paul
paulmceleney
- Chunks
Once you got good full throttle its working back from there.....
You said you'd run out of adjustment????? I assume the needle was set on lowest clip (highest needle position)
Put needle back to middle & get main jetting right (WOT) & then fine tune with needle settings.
paulmceleney
- Chunks
Hi Paul,
I have got a mikuni carb tuning manual in pdf format if you want me to e-mail you a copy of it?
As a guide, I would think you should be around 135/140
http://www.motocarb.co.uk/index.php?_a= ... oductId=61
It might be cheaper to buy a couple of sets in the long run, with the time and effort required trying to drill yours out. Motocarb will supply genuine mikuni jets, next day delivery.
Paul
Paul
Some days I wake up Grumpy.
..................Some days, I just let her sleep.
paulmceleney
- Chunks
update drill jets out to 150 set needle second notch from the top ticking over nice took it for a run pulls like train kept sliding in the seat straight upto 130 no problem if you hold back on the throtle around 5 to6 rpm slight hesitation back to the garage now to adjust the needle setting by one notch hopefully this will cure the problem. also maralyn thanks for your reply i will pm you with my email address
paulmceleney
- Chunks
just been out the bike pulls smoothly in each gear no hesitation ticks over at 1000 rpm still very very slight hesitation if you hold the throttle at 5 6 rpm improvment from last time, try adjusted the air screws but that didn,t work so put it back to where it was, will raise the needle another notch and see if it improves tomorrow
Paul, when you say
What throttle opening is that - slight, half, wide open?????
If its only on slight openning, probably pilot jets a size too small
Needle higher will only enrich 1/4 - 3/4 throttle, not part open
paulmceleney
- Chunks
paulmceleney
- Chunks
