electrics
Mick Hayward
Electrics
Hi John
Disconnect each part at a time to establish which bits and connections are cousing the problem. Something is going down to earth when you switch the ignition on.
Mick
Mick
I agree,if you have had it all to bits you will just have to do disconnects and try again,something is obviously shorting out...........unfortunately you will probably go through a lot of fuses.Start with the easy bits like lights,indicators,horn etc and work your way through,check your switchgear isn,t shorting on the bars all your earths etc. good luck.
Mick Hayward
electrics
Well done John glad you manages to sort it out.
Mick
Mick
