trick z1000
#226 PostAuthor: Ginger Bear » Thu Mar 12, 2009 4:13 pm
Wow Brian, that was quick!
See what you mean, it looks a bit agricultural.
I reckon it's gotta be worth trying to grind it off as TLC says........... You for one will always know it's underneath, & I don't think you're one for compromising, seeing what you have done so far...........
Holeshot
#227 PostAuthor: Holeshot » Fri Mar 13, 2009 9:33 am
Brian,
This is compulsive reading....
Please, please post up shots of all the bracing work you do as a guide to the rest of us who follow in your footsteps.
Keep up the good work fella! :D
brian 450
#228 PostAuthor: brian 450 » Fri Mar 13, 2009 1:10 pm
NEARLY GOT ONE SIDE OUT!!!!! :wink: Trouble is it looks like the weld run down were the frame no was :cry:
#229 PostAuthor: Ginger Bear » Fri Mar 13, 2009 1:23 pm
Easily sorted! Check these out.......
http://www.machinemart.co.uk/shop/range ... 868E7B0ED9
brian 450
#230 PostAuthor: brian 450 » Fri Mar 13, 2009 2:46 pm
Steve R
#231 PostAuthor: Steve R » Fri Mar 13, 2009 3:20 pm
I do not think its too big a problem losing the frame number, you can not read mine at all cos of the powder coating, but the MOT garage are fine with it and just take it off the previous mot or the log book.
#232 PostAuthor: zed1015 » Fri Mar 13, 2009 4:00 pm
Hi Bri. I'm sure you probably know this but thought i'd mention it anyway. When you re-do the bracing don't weld right up to the corner as had been previously done on the plate's you are removing. You need to leave a gap other wise it creates a high stress point. Thats why places such as the top and bottom of the pressed steel swingarm cum engine mount are left open and not coz the japs are being skimpy with the welding rod.
tlc
International Rep
#233 PostAuthor: tlc » Fri Mar 13, 2009 5:05 pm
Brian. I`ve got a set of those number stamps.
From a previous life as a horse thief you understand :lol:
Asphalt Cowboy
#234 PostAuthor: Ginger Bear » Fri Mar 13, 2009 5:24 pm
Just noticed Brian,
Is that a picture of a H***A on your calender :? :?
#235 PostAuthor: Pigford » Fri Mar 13, 2009 6:40 pm
tailiftchris wrote:Brian. I`ve got a set of those number stamps.
Where about does one stamp the numbers on a gee gee then Chris :?:
tlc
International Rep
#236 PostAuthor: tlc » Fri Mar 13, 2009 6:56 pm
One of our associates in the past took key numbers from bikes parked in London squares and got copies made from a shop somewhere close by and then stole the bikes :evil:
We likened him to a horse thief and reckoned hanging was the best remedy :D
Asphalt Cowboy
#237 PostAuthor: chrisu » Fri Mar 13, 2009 7:35 pm
thank god you don't know where I live TLC...............
tlc
International Rep
#238 PostAuthor: tlc » Fri Mar 13, 2009 7:41 pm
Took yer key No. the other Sunday though :lol: :lol:
Asphalt Cowboy
#239 PostAuthor: Rich » Fri Mar 13, 2009 8:12 pm
tailiftchris wrote:Took yer key No. the other Sunday though :lol: :lol:
What's up with a screw driver?
brian 450
#240 PostAuthor: brian 450 » Fri Mar 13, 2009 10:21 pm
Ginger Bear wrote:Just noticed Brian,
Yes I am afraid so it was at the same photo shoot as me :roll: soon will be on the page with the beast!!!! Image
