kickstart
dave m
kickstart
#1 PostAuthor: dave m » Wed Jan 17, 2007 7:06 pm
Hi,
I have a 1978 Z1R which has an emergency kickstarter under the seat, does any body know where I can buy a premanent one finished in chrome.
regards
Dave M :D
Davy Doherty
#2 PostAuthor: Davy Doherty » Wed Jan 17, 2007 7:12 pm
Why ?are you thinking about fixing a permanant one, are you making some changes to it?
Life's too short!
dave m
#3 PostAuthor: dave m » Wed Jan 17, 2007 8:25 pm
When I got the bike the battery was flat and after charging it up I found out that the electric starter is not working due to the cable being broken.
If this happened on a journey home I was thinking on the hassle of fitting this emergency kickstarter in crap weather.
Having a permenant one fitted to the bike is a quick backup.
regards
Dave
#4 PostAuthor: Pigford » Wed Jan 17, 2007 8:46 pm
Dave m, better than trying to 'bump start' the bugger! Also, look cool kicking a bike to life, rather than just sitting & pushing a button! :P
They do seem to fetch good money nowadays tho', and I'd consider getting your under seat one chromed or sumink! :wink:
Ed Z1-R
#5 PostAuthor: Ed Z1-R » Thu Jan 18, 2007 7:49 am
Dave i fitted a kicker off a Z750 twin (same spline size) its on permanent which came into its forte at the 06 Skeggy run,glad i had it fitted :!: but unsure what else will fit.Hope this is of help :D Mmm try john Browse on 01978355556
bedlow1
#6 PostAuthor: bedlow1 » Tue Jan 23, 2007 6:55 pm
used to have a z1 item perm fitted to my z1r with out a problem
dave m
#7 PostAuthor: dave m » Wed Jan 24, 2007 7:55 pm
bedlow1 wrote:used to have a z1 item perm fitted to my z1r with out a problem
Thanks,
Where could I buy one from and how much are they.
Can you get a new one or only second hand available?
regards
Dave
