electric upgrades
mick znone
electric upgrades
#1 PostAuthor: mick znone » Wed Mar 11, 2009 9:32 pm
OK guys, ive got a combined reg/rec [zpower], im ordering dyno s and coils this week, im after denso plugs. would that be the full electric upgrade, or are there other bits. im rubbish with electrics. i know i ask more questions than i answer, but i hope my [childlike] witty banter makes up for it a bit, :lool :no
tlc
International Rep
#2 PostAuthor: tlc » Wed Mar 11, 2009 9:53 pm
Air horns Mick ? :lol:
Asphalt Cowboy
Taffus
#3 PostAuthor: Taffus » Wed Mar 11, 2009 10:02 pm
and for that pure 70's feel
an indicator buzzer :D
mick znone
#4 PostAuthor: mick znone » Wed Mar 11, 2009 10:13 pm
obviously ive already got those :roll:
Kev1R
#5 PostAuthor: Kev1R » Thu Mar 12, 2009 6:28 am
I don't know too much on electrics either -
Has anyone tried the replacement (uprated) stator and able to comment if it offers significant improvement?
If it does what it says it does, it may be worth considering?
see link:
http://www.z1enterprises.com/detail.aspx?ID=1312
mick znone
#6 PostAuthor: mick znone » Thu Mar 12, 2009 7:23 am
thanks ZIRT, that looks interesting, i like this updrade idea on electrics, my last z900 had a charging failure, my presant z1a blew its headlight on last run out, im hoping to put a brighter bulb in this year. as for TLC and Taffus, childlike :roll: just childlike, you know, i'm 45 years old, do you really think i need this kind of silly humour :more :brav
Taffus
#7 PostAuthor: Taffus » Thu Mar 12, 2009 7:36 am
#8 PostAuthor: Ginger Bear » Thu Mar 12, 2009 10:35 am
Mick,
Z1 enterprises is the easiest to fit + all wiring is complete + extra 10-15% output.
I bought one from electrex & while a lot cheaper, it only has standard output & 3 yellow wires...no plug, so will need a bit of faffing around to get sorted.
Z1 enterprises is the easiest to fit, jus plug n' play. + a bit of sealant around the grommet (read all about that in other threads on here).
By the way, I presume them air horns you've got are musical, just wonderin' what tune they play :?
Taffus
#9 PostAuthor: Taffus » Thu Mar 12, 2009 11:42 am
Ginger Bear wrote:By the way, I presume them air horns you've got are musical, just wonderin' what tune they play :?
With Mick being a country boy ........
http://www.youtube.com/watch?v=0e20O2Y4Xe0
mick znone
#10 PostAuthor: mick znone » Thu Mar 12, 2009 6:53 pm
#11 PostAuthor: Ginger Bear » Thu Mar 12, 2009 7:15 pm
Well I can see why you might need a bit more power now! :roll: :roll:
#12 PostAuthor: Rich » Thu Mar 12, 2009 7:27 pm
Put a new loom on it. Ignition switch, both handle bar switches, earth leads, starter cable, solenoid (although you can take them to bits and clean the connectors inside if you are good with a soldering iron), stator and last but not least a new rotor.
cra-z1
#13 PostAuthor: cra-z1 » Sat Mar 14, 2009 7:45 pm
When I did my 73 I used the stator from Jeff at Z1 Enterprises along with the regulator/rectifier combo, Dyna-s ignition/coils/wires,and new wiring harness. Rebuilt the handle bar controls. Good investment to upgrade if you plan on riding the thing.
