Nipples
steve bowdler
Nipples
#1 PostAuthor: steve bowdler » Wed Mar 04, 2009 11:41 am
Yip here we go again :D can someone tell me the thread size of the front bleed nipples on the calipers ,am I correct in thinking they are 7 x 1 mm
steve bowdler
#2 PostAuthor: steve bowdler » Thu Mar 05, 2009 2:44 pm
so I take it no-one can help with the thread size of the bleed nipples on a z1000 a1 front calipers
tlc
International Rep
#3 PostAuthor: tlc » Thu Mar 05, 2009 5:15 pm
Steve. I`ve got some calipers on the bench.
I`ll pull one apart and check.
Asphalt Cowboy
kwakerman
#4 PostAuthor: kwakerman » Thu Mar 05, 2009 10:48 pm
I've just ordered some off a chap on ebay, he told me i would need M10x1.25
hope this helps, Jez
Not mad just kwakers
Z900A4 x2, Z1000A1 x2, z1000A2, z1r, z1a project & a load of bits
steve bowdler
#5 PostAuthor: steve bowdler » Fri Mar 06, 2009 9:05 am
Thanks for your replies , Kwakerman I do not think they are M10 the banjo bolts are M10 and the bleed nipples are a littlt smaller than that.
ARCHIE
#6 PostAuthor: ARCHIE » Fri Mar 06, 2009 3:20 pm
Hello Steve, my 1980 Z is M7 with 1.25 pitch, i think the banjos' were M10. All the bolts on my bike were a 1.25 pitch thread no matter what size.
Hope that helps Archie.
tlc
International Rep
#7 PostAuthor: tlc » Fri Mar 06, 2009 4:36 pm
Ran a tap down the bleed nipple hole.
M7 x 1.0mm
Asphalt Cowboy
Steve Cooke
#8 PostAuthor: Steve Cooke » Fri Mar 06, 2009 7:08 pm
Yep, defo M7 X 1.0 for the bleed nipple and M10 x 1.25 for the banjo bolt.
