Hardware Identification
tlc
International Rep
#1 PostAuthor: tlc » Thu Mar 05, 2009 9:01 am
One for the RIVETT COUNTERS.
I had read somewhere an explanation of the codes relating to the various bolts used throughout the bike, but cannot now find it.
I understand this much but would welcome help in establishing the definitive answer.
110N0625 is a STD headed bolt but with #7 (110) in chrome (N) of 6mm x 25mm.
Other item codes are 113, 114, 116, 120, 172, 220, 221, 310 .......... You get the idea ?
Other finish codes are A, B, D, E, G, F, J, K and Q
Asphalt Cowboy
tedsonthezed
#2 PostAuthor: tedsonthezed » Thu Mar 05, 2009 10:00 am
Only place I've seen something is on Z Power restoration - original Z1. There is one paragraph about bolt i.d.
You want how much?
tlc
International Rep
#3 PostAuthor: tlc » Thu Mar 05, 2009 6:39 pm
Cheers Ted, but Dave is wrong in part.
M6 bolts were originally supplied with number 7 but after the stock ran out they used a number 4.
Asphalt Cowboy
