I need to replace all the screws that hold on the clutch cover etc, I know MandP do alloy screw sets, but ideally I am after stainless.
Any suggestions
Cheers Rob
Replacement engine cover screws
- Mark Stratton
Rob try www.inoxgrp.co.uk they normally can help and their gear is top quality.
phil churchett
Helped these out a few years ago with sizing bolts/screws for Zeds.
Very helpful guy, [sorry can't remember his name].
http://www.inoxgrp.co.uk/homepage.htm
Steve Cooke
Look up a company called A2 / A4 Fixings they have them all, as long as you have the sizes from a parts manual or somewhere. Also if you're changing to socket caps there's no problem, but if you want Phillips type heads to keep along original lines be aware that the heads on stainless ones are often larger than standard Kawasaki ones.
phil churchett wrote:Helped these out a few years ago with sizing bolts/screws for Zeds.
John Kemp, very helpfull knows his stuff too
(\__/)
(")_(")
(")_(")
robw
phil denton from CMM mag do them in stainless or will if you ask.
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
Z1OC # 886
Users browsing this forum: No registered users and 4 guests
