Keep em coming
Have been on the lookout for a tee slot table ect to do just that, it's near the top of a very long wish list . Did actually buy the tap n dia (m14 x 1.5) to make some oil gallery plugs as i have enough bits for two more motors but not another gallery plug in sight.Rich wrote:Miller - put a vertical slide on the lathe.
You could have used one of the Zed oil gallery plugs and just tapped to suit.
I made my own but you can get them through Debben Performance or Direct from Earls Silverstone or Goodridge etc. Most of them come with fitting for the oil pressure switch otherwise you'll have to fit a pressure gauge feeding off the end of the main oil gallery as i have done.brian 450 wrote:LOOKING GOOD.....when i fit a cooler on my Z where do i get the bit for hose to fit on engine ? or do i have to make it? Brian
Users browsing this forum: Bing [Bot] and 3 guests
