carbs
paulmceleney
- Chunks
carbs
ive changed the o rings that are on the drain off screws and petrol is still leaking can anyone help thanks paul
Paul, are you sure the leak is from the drain screws? Another place that the petrol can leak from (in close proximity to the drain screw) is the overflow brass nipple. I have seen these get a longitudinal split or crack hardly visible to the naked eye.
paulmceleney
- Chunks
thanks garn1 i will have a closer look i thought i would post this question before i put some silcone on the thread ,i have four sets of carbs in boxes and they all leak is this a fault with these bikes or just my ive got to fix this little problem the petrol fumes are upsetting my asthma please anyone do reply thanks paul
Mick Hayward
carbs
I've had a similar problem. the brass overflow pipe in the float bowl had fractured causing constant flooding of the carb.
Regards
Mick
Regards
Mick
Paul,is it just one carb leaking or all of them? I would be surprised if all four were cracked,are they the correct o-rings? we use a spray on developer at work which allows you to pinpoint the leak from the staining on the powder,just trying to think what you could use instead (talc powder is a possible solution
Good luck, Steve.
Good luck, Steve.
SteveS, I also would be surprised if all the overflow pipes were fractured the way described previously. It is an unsual but a real problem that does occur. I am please Mike H has also seen it, otherwise I would be "one-out". It was terribly hard to isolate where the petrol was leaking. It is likely to be only one float bowl leaking, if indeed it is the problem.
RegardZ
RegardZ
I too have experienced the longitudinal split or crack hardly visible to the naked eye along the brass overflow pipe. Until now I thought I was the only one! I did manage to get hold of a replacement carb bowl - courtesy of Mr Marsden.
Just out of interest - Is anyone aware of a means of repairing the split?
paulmceleney
- Chunks
Mick Hayward
carbs
Hi Guys
I was really surprised to find this type of fault. Origionally 2 carbs were floodiing and 2 were bone dry, obviously a float valve/seat problem and a cosequent strip was required. I only noticed the break in the overflow pipe on reassembly. It just fell off. Tried to remove the old nipple but couldn't do it. Am getting a replacement float bowl now. I think in the case quoted I would go for float valves and seats. Chances are something else is gummed up as well.
Regards
Mick
Regards
Mick
Z1RT311 wrote:I too have experienced the longitudinal split or crack hardly visible to the naked eye along the brass overflow pipe. Until now I thought I was the only one! I did manage to get hold of a replacement carb bowl - courtesy of Mr Marsden.
Just run some solder down it with an iron?
Press some plastic pipe over it to seal it as long as it isn't all the way down?
Pull the old one out and put a new piece of brass tube in it?
paulmceleney
- Chunks
