Pigfords OLD effort......now JULES NEW PROJECT!!!!!
steve.w
#211 PostAuthor: steve.w » Sun Feb 22, 2009 10:44 pm
CARBS :roll: :roll: :roll:
Dodgy Z1B
#212 PostAuthor: Dodgy Z1B » Mon Feb 23, 2009 12:05 am
I would say Steven Cooke's right pigford had the same thing with a gs750 and cb550 when fitted bellmouths and kn's on the 550 turned the air screw full in and it didn't hang anymore and ran fine but if set the airscrew to 1-1.5 turns out the thing used to hang etc. so I would agree too weak on primary setup.
#213 PostAuthor: Rich » Mon Feb 23, 2009 5:55 pm
Explain "hangs up".
Stuttering missfire, does it clear with more throttle or less?
Can it be coaxed through it with the choke?
Does it happen when under load an driving or also in neutral?
Is it specific to a rev range or does it happen when rolling on the throttle at any revs?
Is it better when hot or cold?
Dodgy Z1B
#214 PostAuthor: Dodgy Z1B » Mon Feb 23, 2009 6:20 pm
I think he means when reved then throttle closed the bike revs dont drop right away.
#215 PostAuthor: Rich » Mon Feb 23, 2009 7:32 pm
Does it die after a while? - too rich pilots.
#216 PostAuthor: Pigford » Mon Feb 23, 2009 8:34 pm
Thanx for the replies lads....... :wink:
Rich, as Dodgy says...... it will idle nicely (all day long) until you give it a decent tweak on the throttle, & then the revs WON'T drop, just stays high (3000 rpm - guess) & stays there.......
May creep up after a bit but don't let it stay high coz it sounds like it may self destruct :lol:
I think i'd better re-check the manifold rubbers for leaks..... I did seal them with permabond sealent on assembly, but as I have had the carbs on & off loads of times they may have been disturbed :?? Especially over the cold winter - hard rubber.... :evil:
The 36's off the black Z1000 is running 20 pilots with 140 mains......
In the 38's I did try 17.5 pilots, and 25's & 32.5's :??
Mains ranged from 135 - 145- 155- 165 :shock:
GB, thanx for the kind offer, but the 36's where fine on me black Z1000, and the same problem occured using them instead of me recently purchased 38's.... :evil: But, I may be in touch :wink:
kano
#217 PostAuthor: kano » Tue Feb 24, 2009 1:04 am
i just remembered i had a similar problem.
would start and idle on choke as it idled no prob tweak the throttle and the idle would stick at 3000rpm.
turned out the clamp on number 3 carb was hitting the throttle mechanism,
the bolt was stopping the carb from returning.
and it to me ages to figure it out.
i live and ride in the states but im British and bloody proud of it!
http://www.kz1000r.com/
mikey
#218 PostAuthor: mikey » Tue Feb 24, 2009 6:37 am
Had a similiar one on my A2 when i first got it on the road it wouldnt tick over below 3,000 rpm and that turned out to be the throttle linkage was slightly bent just enough to hold the throttle open a tad.
#219 PostAuthor: Rich » Tue Feb 24, 2009 6:24 pm
I'd go for Kanos first if I were you, plus cable routing and associated twistgrip problems. Swapping the carbs should eliminate poor slide adjustment damaged parts etc unless you've done the same on each set!
Are your cables the right length and do you have some slack in them?
Do you have filters on or velocity stacks. Are the slides hitting the stop when shutting off?
Is the return spring strong enough. if you positively return the slides (do they have a spring mechanism AKA 28s and sbores) does the cable spring compress?
Oil the cables - you'll be amazed what a difference it makes, while you are doing it check out the twistgrip action.
kano
#220 PostAuthor: kano » Sat Mar 07, 2009 6:37 pm
hows it going pigford?
problem solved yet?
#221 PostAuthor: Pigford » Sat Mar 07, 2009 7:30 pm
Hi Kano...... Thanks again for nominating this bikes for the 'Bike of the Month' :wink:
I was down a Debbens today, & Ray sujested I do check cam timing & look for any air leaks (manifolds, valves not closing properly, valve clearances, cracks in head... etc) :??
Haven't had time to degree the cams in, so need to do that first.
I got another cam gasket off him as the one I have is wafer thin & not sealing too well :roll:
Once this problem is sorted, she's on the road.... :twisted:
kano
#222 PostAuthor: kano » Sat Mar 07, 2009 10:24 pm
very good seems like you have a plan.
what jets are you currently running?
take some more pic's asap bigger the better for the front page.
it was a bit of a rush job this bike of the month
and your bike is well worthy bro you just don't think it is i am the same
with my bike i never thought ppl would like my bike but they do funny really lol.
any way keep at it.
oh by the way i really want one of the pic's to have the owner of the bike
i,e you! as i think its really cool seeing the owners too who put in the wrench time.
#223 PostAuthor: Pigford » Sat Mar 07, 2009 10:28 pm
Kano, OK matey..... I'll get me best togs on & do a photo shoot tomorrow.... :P
Won't be staged in the KITCHEN or DINING room though :shock:
kano
#224 PostAuthor: kano » Sat Mar 07, 2009 10:34 pm
oh geeze that sounds scary lol.
kano
#225 PostAuthor: kano » Sun Mar 08, 2009 3:13 pm
looks like the old girl cleaned up really nice there pigford.
now we just have to clean you up, :lol:
