Z1000-A1 rear foot peg fitting
tpr
#1 PostAuthor: tpr » Sat Jan 31, 2009 1:07 pm
I got some new Kawasaki rear footpegs but the holes on the pegs don't line up with those on the bracket. Any tips on how to make them fit?
Z900-A4, Z1000-A1
Steve Cooke
#2 PostAuthor: Steve Cooke » Sat Jan 31, 2009 1:13 pm
You should be able to force it by compressing the rubber then it wont rattle when fitted as long as the metal is not bottoming out on the inside.
tlc
International Rep
#3 PostAuthor: tlc » Sat Jan 31, 2009 3:07 pm
What he said.
The rubber acts in the same way as a compression spring.
Asphalt Cowboy
mick znone
#4 PostAuthor: mick znone » Sat Jan 31, 2009 5:40 pm
you could try putting the pegs in hot water for 5mins, if they are tuff.
tpr
#5 PostAuthor: tpr » Sun Feb 01, 2009 5:26 am
Thanks for your help. I had tried compressing the rubber but hot water was the key for these ones.
Z900-A4, Z1000-A1
mick znone
#6 PostAuthor: mick znone » Sun Feb 01, 2009 8:34 am
thats cool man, i found this method out after struggling with condoms, leave them in hot water for 5mins, then they will stretch to my size. incidently, 5mins i find is just enough time for the foreplay :lan
