DROUIN Supercharged Z1000.
rickman CRR
#16 PostAuthor: rickman CRR » Thu Jan 29, 2009 5:58 pm
#17 PostAuthor: Pigford » Thu Jan 29, 2009 6:44 pm
Stunning.........................
Want some spec details on this beasty :twisted:
You gotta get to Santa Pod in October... :wink:
ted1r
BIKE
#18 PostAuthor: ted1r » Thu Jan 29, 2009 7:35 pm
very very VERY NICE AND ONLY 20 MINS AWAY FROM ME,OR EVEN LESS IF I`M AT WORK :!:
#19 PostAuthor: zed1015 » Thu Jan 29, 2009 8:08 pm
Here's one from the front. Got a nice roundy headlight going on as soon as i finish the mount. Quick spec of motor - Dry blocked 1000A cases + gearbox. welded Z900 crank. 8-1 comp 1075 wiseco's. 1000 J head ,eight plugged/gasflowed/skimmed 1.3mm. std cams dialled in at 110 deg. blower geared for 8 to 10 psi boost for running in. plus all the usual APE/Liska/Falicon/Orient express/Camellia/PMC/Dyna and my own bits'n'bobs here and there.
Pasc
#20 PostAuthor: Pasc » Thu Jan 29, 2009 8:19 pm
What do you mean by "dry blocked" Zed ?
Big John
#21 PostAuthor: Big John » Thu Jan 29, 2009 8:19 pm
Rob that is the mutts nuts, why lengthen the swingarm? wheelies are much more exciting :lol:
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
tlc
International Rep
#22 PostAuthor: tlc » Thu Jan 29, 2009 8:29 pm
Blowers ROCK :D
Asphalt Cowboy
baldy brent
#23 PostAuthor: baldy brent » Thu Jan 29, 2009 8:50 pm
BLOODY WICKED!!!!!!!!!!! :D
kz900B1
#24 PostAuthor: kz900B1 » Thu Jan 29, 2009 9:27 pm
Looking good.Better get training to hold on. :lol:
colinKZ900B1
GUYZED
#25 PostAuthor: GUYZED » Thu Jan 29, 2009 10:00 pm
Gorgeous :drool :drool :drool
#449
Z1000A2 Z650B1
#26 PostAuthor: zed1015 » Thu Jan 29, 2009 10:13 pm
Pasc wrote:What do you mean by "dry blocked" Zed ?
Hi. you will see that i have external oil feeds (for a cooler oil flow) to the cams, so there is no need for the oil to run up the rear outer studs, so the small hole in the crankcase at either end of the main gallery is plugged and also in the head so that oil cannot flow down ,hence the Dry block. Originally used to prevent oil seepage and a resulting lowered oil pressure on big bore drag engines (especially with copper head gaskets)where the gasket area is greatly reduced.
gbh
#27 PostAuthor: gbh » Fri Jan 30, 2009 12:55 am
Feck, if someone is going too build a special they might as well go balls and all.....that is bloody beautiful and it hasn't even painted yet!
What colour are you going to paint it?
shrekward
#28 PostAuthor: shrekward » Fri Jan 30, 2009 9:18 am
Ted
shrekward
#29 PostAuthor: shrekward » Fri Jan 30, 2009 9:19 am
What I meant to say was, it'll be quicker than 20 minutes when that thing gets going!
Just let him come to you Ted, it'll be quicker! :shock:
Padders
#30 PostAuthor: Padders » Fri Jan 30, 2009 11:32 am
Lovely bike
