Spark Plugs
Spark Plugs
I've recently switched from NGK to Denso IW24 plugs. Once she is running I can definitely state that she is much smoother at low rpm, in other words the lumpiness has gone. The trouble is starting, doesn't start on first go now and mostly the no. 2 gets wet and I have to take it out and clean it. Has anyone else had this problem or could it be something else???
As always any input appreciated.
B
B
Lost in the desert somewhere
- london calling
- london calling
That's reassuring about the plugs thanks LC. The no. 2 plug fouled up when I first got the bike a couple of times and since I rebuilt the top end (Monday) it's happened twice, so maybe I ought to look at the carbs. Not a scooby doo where to start with the carbs mind you, but I'll learn.
You`re a bit of a fiddler aren`t you ?
I did my carbs and had a misfire on No.2 afterwards.
Turned out that the main jet fell out in that carb
I`d have a look inside the float bowls and the slides, a complete strip really, but make sure you have the means to balance them after !
Asphalt Cowboy
- london calling
You might want to get some Dyna/hi-output coils if you need to replace/up-grade your ignition.
Also check that you're getting a good reliable 12v feed to your coils.
www.denso-europe.com
Jack
or this...................
http://www.wgcarbs.com/index.php?option=com_content&task=view&id=12&Itemid=26
- london calling
- london calling
