Has anyone got any advice about fitting a Manual Cam chain tensioner to a Z900A4 standard engine? What can happen if it's done up too tight?
As usual your advice greatly appreciated.
Manual Cam Chain tensioner
Lost in the desert somewhere
- big green bus
Rotate the engine forwards gently for a couple of revolutions, with the plugs out, using a spanner/socket on the 17mm adv/ret nut so that the slack is generated at the tensioner while doing the tensioner up with your fingers. Then stop and back the tensioner bolt off 1/4 turn and lock it off. Do not rotate engine using kickstart lever.
