O ring size Brake caliper Z9A4
Does anyone the know the size of the O ring for the dust seal on the brake caliper for the Z900 A4?
Lost in the desert somewhere
- Davy Doherty
I did and damaged them, as you do! I've actually found an excellent tool shop down here which supplies O rings. I have searched all my books but nothing about the actual size. I'm guessing they're 10mm. I agree Z Power is great in getting stuff out to me, it's just the postal service over here is a bit hit and miss.
- mick znone
got to strip my calipers down, think i have o rings missing as they clatter about on the bracket. i have a box of assorted o rings which i use for work and hoped to use them. any DIY shop or builders yard stock them. providing nothing gets in the way i am stripping them in the morning. according to the zpower parts book you need 8 rings for the a4 and 4 for the z1a. but there are all sorts of bits of rubber in them, so a will probably end up buying a kit.
The trouble I had was getting the bolts to go through the bracket without trashing the rubber. When you say 8 O rings are needed do you mean 4 per caliper?
- mick znone
Try using a little vaseline, it certainly helped me!
