sprockets
ted1r
sprockets
#1 PostAuthor: ted1r » Wed Dec 31, 2008 4:25 pm
Hi and Happy New Year :D
Has anybody got a pair of new or nearly new Z1r front and rear sprockets for sale? I need a 15 and 33 .
Regards Ted
compo z1r
ted z1r
#2 PostAuthor: compo z1r » Wed Dec 31, 2008 5:42 pm
hi' ted bike torque racing on 01373 464252 has what you need.
part no's are front 24800-15 £10.51 + vat
rear 16601- 33 £20.71 + vat
chain a630-5-92 links. £78.92 +vat
hope this helps ted .
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
ted1r
sprocket
#3 PostAuthor: ted1r » Thu Jan 01, 2009 1:10 pm
thanks compo
greenlaningxt
Sprockets
#4 PostAuthor: greenlaningxt » Fri Jan 02, 2009 3:24 pm
While on the subject of sprockets.
Some one on here said awhile ago the the latter Zs had an offset 17 tooth front sprocket.
Any one any idea of parts numbers or have an old one I could try.
Want to see if I can get one on the Harris with the Hydraulic cly on.
Harris Z1000, Several other Road, Off Road and Trials Bikes, Delica Exceed
http://www.greenlaning.co.nr
ted1r
sprocket
#5 PostAuthor: ted1r » Sun Jan 04, 2009 1:59 pm
Its certanly not Z1r as the 15 tooth has just enough to clear the casings when the chain is on.
Regards Ted
Keith
Sprockets
#6 PostAuthor: Keith » Sun Jan 04, 2009 3:14 pm
Ted
Been looking round myself and best "deal" for DID i've found so far is Z Power ;
"Chain and sprocket kit (DID)
[CSKKZT15/33] £120.00
A chain and sprocket kit for the Z1000A1/A2 AND Z1-R AND Z1000-LTD Models. front sprocket: 15 teeth, rear 33 teeth. chain is a DID 630VS x92 links. The chain is a split one with a rivett link supplied."
Keith
#7 PostAuthor: Pigford » Sun Jan 04, 2009 5:28 pm
Z1000R & early GPz has an off-set sprox :wink:
ted1r
sprocket
#8 PostAuthor: ted1r » Sun Jan 04, 2009 5:28 pm
Thanks Keith ,I have a new chain, Zpower will be best Ill ring them and get them sort some out for me.
Regards Ted
Re: Sprockets
#9 PostAuthor: Rich » Sun Jan 04, 2009 6:37 pm
greenlaningxt wrote:While on the subject of sprockets.
What engine? What chain? Gearbox output shaft changed at J model
greenlaningxt
Sprockets
#10 PostAuthor: greenlaningxt » Mon Jan 05, 2009 11:40 am
Mine is a Z1000A2 630 chain fitted in a Harris frame with a Fireblade 180 back wheel with a small sprocket fitted.
Hence the need for an offset sprocket.
Have a Offset Billet 16 tooth front sprocket on there now but wanted to see if I can get a 17 on there without the expense of another billet sprocket.
#11 PostAuthor: Rich » Mon Jan 05, 2009 6:36 pm
You' ll probably have to cut away the casing to get a 17 on and it will probably be very close to the pushrod.
The only "OEM" front sprocket has a 6mm offset and is off a gpz750a1 but usually only available with 15 teeth.
http://www.jtsprockets.com/52.0.html?&L ... id=1145&p=
You should be able to work out what the radius will be for the different sprocket and chain to see it it will fit
3/4 x 17 = 22/7 x 2 x r = 2.0284 inches plus half height of chain
should give the approximate radius of the new sprocket plus chain.
I would leave a couple of mm more for any throw out when changing gears / overrun etc
greenlaningxt
Sprocket
#12 PostAuthor: greenlaningxt » Mon Jan 05, 2009 8:03 pm
Already been down the GPZ750 route, I have a 15 tooth offset from one in my spares pile!
I am sure I read someone saying some of the later Zs had an 17 tooth offset sprocket on them.
Will have to go though a lot of posts to find it I guess.
#13 PostAuthor: Rich » Tue Jan 06, 2009 3:50 pm
Splines change at J
