Z1000 slightly modified
- paul doran
- paul doran
- paul doran
- london calling
- Davy Doherty
Like Jack says probably sold it to a mate down the pub or took it off cos the starter clutch slipping. Ask him if he still has it lying around.
To save weight but why leave the starter motor on.
Are they 26mm Keihins
Still don't see any pics of the F1
- paul doran
- paul doran
- paul doran
interesting carbs you have Paul. I found a set in a local wrecker and intent to fit them to my Martin project.. (if I ever get any further than colecting parts) No point posting photos, its still just a pile of parts waiting for more bits to get started. My carbs are individual, came off a speedway midget motor. Ineed to make a mount, coupling for the cables so if you can post some more photos so I can get ideas.. Thanks
- paul doran
- paul doran
petez1 wrote:interesting carbs you have Paul. I found a set in a local wrecker and intent to fit them to my Martin project.. (if I ever get any further than colecting parts) No point posting photos, its still just a pile of parts waiting for more bits to get started. My carbs are individual, came off a speedway midget motor. Ineed to make a mount, coupling for the cables so if you can post some more photos so I can get ideas.. Thanks
Peter I wont be fitting these carbs to this bike but I will dig out the throttle linkages and let you see them
paul doran wrote:Rich it has a MK 2 Crank as the A1/2 rotor won't fit the MK 2
I removed the cover and sure enough MK 2 Rotor
the point's cover is a big four engineering replacement one
If you'd have asked I could have saved you the trouble of taking the cover off
I think it maybe just a sticker in a gpz cover.
