Pigfords OLD effort......now JULES NEW PROJECT!!!!!
#106 PostAuthor: Pigford » Mon Dec 01, 2008 6:57 pm
Just to prove the skeptics (not Septics) wrong.....
I am refurbing the front brakes on me ELR........ They have been painted white at some point... and look sh*te :evil:
The brakes were about 6/10 on me last ride out..... and now I've stripped them I can see why.....
The pistons were really manky (the left one is after I spent 5 mins trying to clean it up) and pitted. :??
I ordered new sets (£60 for both pistons & seal kits) from www.wemoto.com on Friday - late am - and they turned up next morning :P Got a large tin of paint stripper, so will be working on them soon.
My engine will be grit blasted this Wednesday (hopefully) so can start assembly this weekend, all bits now ready - O rings/seals.. etc :twisted:
d123456789p
#107 PostAuthor: d123456789p » Wed Dec 17, 2008 9:35 pm
I have a Z900 in similar state of repair........I can't be arsed to get up and do it.......so ashamed man!!! :oops:
I do exactly what it says on the tin..............and its Dave if you must know
#108 PostAuthor: Pigford » Wed Dec 17, 2008 9:39 pm
Dave, I know what you mean..... I take it in bite-sized stages :wink:
Got some more PJ1 - satin black, so can finish off me spraying engine tomorrow (at work) :twisted:
Gonna do the calipers too.... :P Then get the stuff home ready for the XMAS assembly.... :lol:
RALPHARAMA
#109 PostAuthor: RALPHARAMA » Wed Dec 17, 2008 11:06 pm
Mark, don't paint yer calipers.... I made that mistake myself .... you're bound to drip some fliud on 'em and then they will be .. er unpainted in bits ... talk to Griff's Reality Motorcycles in Kingswood and get 'em vapour blasted and powder coated ... it really is worth the expense - they look original and will stay that way :D And it's prolly less expense than you might imagine :shock: Also learn from my mistakes and stick in some stainless bleed screws, wish I had ... I'll change mine in the spring when I do my annual fluid change :oops:
Ralph Ferrand
Jappen
#110 PostAuthor: Jappen » Thu Dec 18, 2008 2:31 am
Use silicone brake fluid. It dont mess whit the paint :tra
80-Z1000H
79-Z1000MK2
Magnum1
#111 PostAuthor: Magnum1 » Thu Dec 18, 2008 9:56 am
HOPPA wrote:Thanks mate, i'll have another yarn with my mechinist, love to use the 75mm kit, thats what i bought it for. cheers
Tell you what, last time I used a set of WISCO pistons we weighed them to make sure and one of them was out by a few grams. Had to machine a bit off to get them evenly balanced. Not saying this is common, but worth checking before you bung them in.
Rod :wink:
#112 PostAuthor: Pigford » Thu Dec 18, 2008 7:09 pm
Magnum..... I weighed mine :twisted: The scales are calibrated and measure to 0.1g...
I did pistons with wrist pins and they were all within 0.2g....
Ralphy.... Cheers for the advice, but a couple of hours too late :oops:
Painted them today at work :?? I'll take Jappens advice & give silicon stuff a go.... nothing to lose now :wink:
Is there a laquer that can be used :?:
tlc
International Rep
#113 PostAuthor: tlc » Thu Dec 18, 2008 7:17 pm
Pig. I used PJ1 porcelain hard paint.
I`d much prefer to do things again than something more permanent that I have to live with................................like plastic coating :twisted:
Asphalt Cowboy
RALPHARAMA
#114 PostAuthor: RALPHARAMA » Thu Dec 18, 2008 7:22 pm
I'd be very careful about the effect of non-standard brake fluid on your seals. I don't know of any lacquers that are any less vulnerable to the effects of nice fresh brake fluid. I suppose you could do what I did, put 'em together, bleed 'em up, spill a small amount of fluid, wash it off, curse then take 'em all apart again and send 'em off for plastic coating :lol:
Ralph Ferrand
#115 PostAuthor: Rich » Thu Dec 18, 2008 7:23 pm
If you are going to silicon you will have to replace all seals.
#116 PostAuthor: Pigford » Thu Dec 18, 2008 7:24 pm
Perhaps I'll cover them in a nice Tesco bag whilst bleeding them :|
tlc
International Rep
#117 PostAuthor: tlc » Thu Dec 18, 2008 7:29 pm
Don`t listen to Ralph, he`s just clumsy :!:
Use a pipe to vent off in to your milk bottle or whatever and have some brake cleaner handy.
Also helps if the paint is dry before you try filling `em with fluid. :wink:
Asphalt Cowboy
#118 PostAuthor: Rich » Thu Dec 18, 2008 7:41 pm
Mark - looking at the state of them it'd probably be worth chucking them in a bin and looking for something else :D
kwakerman
#119 PostAuthor: kwakerman » Thu Dec 18, 2008 10:47 pm
you could allways fill them from the bottom using a syringe which should in theory expel any air bubbles into the master cylinder as the fluid rises.
might try that on mine as they have just been freshly painted, just waiting for stainless pistons to arrive.
Jez
Not mad just kwakers
Z900A4 x2, Z1000A1 x2, z1000A2, z1r, z1a project & a load of bits
RALPHARAMA
#120 PostAuthor: RALPHARAMA » Thu Dec 18, 2008 11:36 pm
I use a vacuum bleeding system, and in a perfect world I would never drip any fluid anywhere, but in the real world the stuff has a habit of dripping un noticed from the side of the bottle on to your gloves which then transfers to .... and sooner or later the spanner you pick up just touches the freshly painted calliper and Oh shit, get me detergent and fresh clean water quick .... oh shit, that fekking drip was only on there ten seconds and ... fek, fek, fek :grr :grr :grr :grr :grr :grr If a part lives in an environment where it's likely to come into contact with the world's best paint stripper, doesn't it make sense to use a covering that's not ... er vulnerable to paint stripper? :shock:
Ralph Ferrand
Users browsing this forum: No registered users and 3 guests
