a4 poject rebuild
Liam Crowe
a4 poject rebuild
#1 PostAuthor: Liam Crowe » Tue Dec 02, 2008 7:56 pm
Stable Mate
http://i372.photobucket.com/albums/oo17 ... G_3667.jpg[/IMG]
TOP C/CASE
I am pointing at the part i need help with - what way it the rachet part of the kick start to be fitted?
Oil seal - I have the flat part into to the casing??
phil churchett
#2 PostAuthor: phil churchett » Tue Dec 02, 2008 8:31 pm
Liam,
let's see some pics of your Triumph :D
tlc
International Rep
#3 PostAuthor: tlc » Tue Dec 02, 2008 8:47 pm
A garage with a pit ! I`m impressed :)
Asphalt Cowboy
mikey
#4 PostAuthor: mikey » Tue Dec 02, 2008 8:52 pm
Yeah show us the triumph, show us the triumph!!!!!!
Pasc
#5 PostAuthor: Pasc » Tue Dec 02, 2008 9:30 pm
Triumph knew how to style a bike. Coolest looking bikes on the planet.
Liam Crowe
a4 project rebuild
#6 PostAuthor: Liam Crowe » Tue Dec 02, 2008 9:38 pm
Hi Everybody,
I will get my Triumph out and will post picks.
Any help with the photos
Liam :fly
#7 PostAuthor: Al » Tue Dec 02, 2008 10:30 pm
Liam i can help with two of the photos.
The 'O' ring is correct if you are looking at the tapered side as i believe you are.
Other photo shows a busy garage and i may be able to help by finding a home for the baby trumpet just to free up some space for you.
Steve Cooke
#8 PostAuthor: Steve Cooke » Wed Dec 03, 2008 6:26 am
The oil seal is correct and the ratchet is correct, if you had the kickstart shaft dismantled make sure that the marks on the shaft and the ratchet are aligned. Also I cant see the washer tabs on the photo but make sure they are there and bent into place it should be renewed ideally and use some thread lock on the bolts.
Liam Crowe
a4 project rebuild
#9 PostAuthor: Liam Crowe » Wed Dec 03, 2008 9:39 am
Good Morning Lad's
Thanks very much for the advice.
On the Triumph - very Sorry no money will make me part with her - well nearly no money :D
Can i put the bottom end back togother leaving out the return spring and spacer in the kick start shaft - Kick start shaft was not dismantled so that should be O.K and the bolts will get some therad lock also
Oil seal advice is understood and thanks
What sealer would be put with the gasket when putting the two casing ends together
:resp
Liam :fly
#10 PostAuthor: chrisu » Wed Dec 03, 2008 10:58 am
i use the stuff sold by Z1enterprises.com - can't remember the name of it though but it works a treat.
DogsbolloxofZ1B
#11 PostAuthor: DogsbolloxofZ1B » Wed Dec 03, 2008 11:33 am
Yes you can leave the return spring and collar out, these two parts are fitted when the cases are mated. I always use kawabond to seal the crankcase halves, available from zed-power in Black & silver (Silver for yours)
Mike
Liam Crowe
a4 project rebuild
#12 PostAuthor: Liam Crowe » Wed Dec 03, 2008 9:15 pm
Liam Crowe
a4 project rebuild
#13 PostAuthor: Liam Crowe » Wed Dec 03, 2008 9:17 pm
:fly
mikey
#14 PostAuthor: mikey » Wed Dec 03, 2008 9:21 pm
That triumph is simply gorgeous liam, can see why youd never part with her, shes a beauty for sure.
Liam Crowe
a4 project rebuild
#15 PostAuthor: Liam Crowe » Wed Dec 03, 2008 9:27 pm
Thanks Very much Mikey :resp
Regards
Liam :fly
