73 Resto - "Now this is not the end. It is not even...
MaineKZ
#16 PostAuthor: MaineKZ » Sun Nov 30, 2008 9:38 pm
Thought it was time for a wee update. Just reached that feelgood stage when everything's stripped, cleaned, bagged and ready to ship out to the professionals.
I've spent a lot of time stripping, de-rusting and prepping billions of parts for re-zincing: I know a lot of folk are happy to dump a huge great bag of stuff straight off the bike onto the plater's doorstep. I'm a bit wierd - I like prepping stuff - just my thing.
For those new to this, the parts are degreased in petrol, then the stripping/derusting is done with brick cleaner - undiluted. Finishing is then done with a rotary fibral mop - fine grade. This imparts a lovely fine satin finish which the BZP sits on really nicely. Also, the cleanliness of this finish allows the best possible adhesion of the plate (after a final clean at the plater).
The following shots show what this 'mopping' does, versus the 'ex-acid' finish: the footrest body in the pic has been mopped half way only. I'm not a complete nutter, don't mop the parts that aren't visible.
I included the brake hose just to re-assure first time restorers that it's fine to re-zinc hoses - the rubber is unaffected by the stripping acid. The spring shroud is bound up to keep it out of the acid, I didn't want it's finish damaged:
One the subject of the shiny stuff, here's a shot of some original fixings. the back row made the cut and will go straight back, the front row are too pitted and will be re-plated. All chroming will be done to match original standard so it will not be mirror polished before plating. this will leave some pitting undressed, but I prefer that to the 'show chrome' look.
A few more shots now of the frame. This is now ready to go off for blasting - I will be spraying it to keep the finish as authentic as possible. To that end, I decided it was worth taking time to mask the headstock sticker against the blasting: when it's done I'll hand finish around the sticker then feather the spray to minimise the mask line. the sticker's in great shape so I wanted to hold onto it. An off cut of 2" waste pipe was perfect for the job.
A few shots of the wheels now. Again, trying to keep some 'patination' to the bike, I'm using the front hub as is - I like a few scars, that's what gives the bike character.
As you'll see, the rims are quite presentable: some pitting, but I like that, and I'm avoiding re-chroming wherever possible in favour of keeping the original finish, even if it's 'weathered'.
The rear hub centre will be cleaned up with a 'ribbed' fibral mop - looks just like it's been vapoured. Spoke flanges will be linnished.
I included the sprocket hub in shot because its finish is interesting: it not linnished or polished - pure sandcast finish. I'm sure it's the original so it'll stay like that.
The brake hub is one I bought from the US. correct 73 without wear indicator. The alloy has been roughly linnished to accept a paint finish that someone had applied. This will need to be polished up - but not to mirror - that's not what they did ex-works.
Lastly, the seat. Again, this is the original, with the original 2 part foam. The inner black section was supposed to enhance comfort. ho hum. The base is typically corroded but will clean and spray up fine. I will probably recover with a very good repro cover I bought from the US which matches the original to the stitch. The original cover is interesting: you can see how the thin foam inserts in the top face have perished, hence the top has lost all it's contour. The new cover will re-instate that 'padded' look. I was careful in removing the original - might just use it on another project some day!
I used a table knife to separate foam from base. Don't use anything pointed or sharp or you'll damage the foam!
Coming up in the next update - dismantling the original rear shocks. My home made compressor jig should do the job:
tlc
International Rep
#17 PostAuthor: tlc » Sun Nov 30, 2008 9:45 pm
Fascinating Chris.
Asphalt Cowboy
steve f
#18 PostAuthor: steve f » Sun Nov 30, 2008 10:03 pm
nice details and pictures but the blue gloves spoil it :beer
I love old paul doran
Taffus
#19 PostAuthor: Taffus » Sun Nov 30, 2008 10:16 pm
Great Stuff!
How do you linish? got sold a linishing bar with a polishing kit, all I have ever managed is to get covered in linishing bar with none on the mop :(
(\__/)
(")_(")Image
#20 PostAuthor: Pigford » Sun Nov 30, 2008 10:35 pm
Good stuff :twisted: kEEP UP THE DETAILED WORK....
The 'Brick Cleaner' is HYDROCHLORIC ACID...... :wink:
MaineKZ
#21 PostAuthor: MaineKZ » Sun Nov 30, 2008 10:59 pm
Pigford wrote:Good stuff :twisted: kEEP UP THE DETAILED WORK....
Still - not bad with plenty of ice and a twist of lime though :wink:
wilsonsjw11
#22 PostAuthor: wilsonsjw11 » Mon Dec 01, 2008 6:18 am
MaineKZ
WHO DID YOUR ZINC PLATING AND RECHROMING PLEASE?
Regards
Steve
steve f
#23 PostAuthor: steve f » Mon Dec 01, 2008 6:44 am
i like your rear shocker splitting tool its a bit safer than my vice 2 tyre leavers and another pair of hands
Steve Cooke
#24 PostAuthor: Steve Cooke » Mon Dec 01, 2008 6:54 am
Nice work Maine, but do you not have any worries about restoring a 35 year old rubber brake line that weren't that great to begin with, I wouldn't risk my life with those, I don't think i'd get much comfort laying across someones bonnet and looking down at my bike and thinking well at least my brake lines look original.
MaineKZ
#25 PostAuthor: MaineKZ » Mon Dec 01, 2008 8:37 am
Steven Cooke wrote:Nice work Maine, but do you not have any worries about restoring a 35 year old rubber brake line that weren't that great to begin with, I wouldn't risk my life with those, I don't think i'd get much comfort laying across someones bonnet and looking down at my bike and thinking well at least my brake lines look original.
Fair point there!
But you might take that further and ask - who'd be fool enough to ride an 500lb, 82bhp motorcycle with one single pot front brake up front?!
Ride to the limitations of the bike - that's my motto with these old girls.
Fortunate that the hoses are very visible so any sign of deterioration and the hoses will be replaced - pronto!
gbh
#26 PostAuthor: gbh » Mon Dec 01, 2008 9:23 am
â€Â￾This is now ready to go off for blasting - I will be spraying it to keep the finish as authentic as possibleâ€Â￾
[b]Thank you MaineKZ, I am glad to see that you are not using the usual method. Powdercoating....bloody vandalism[/b]
hal
#27 PostAuthor: hal » Mon Dec 01, 2008 11:40 am
Great write up and pictures, the finish on the parts prior to bzp is excellent. I am going to start restoring my Z1B soon, the brick cleaner and 'ribbed' fibral mop does a fantastic job. But i am not sure exactly what a 'ribbed' fibral mop looks like could you please post a photo of it?
MaineKZ
#28 PostAuthor: MaineKZ » Mon Dec 01, 2008 1:33 pm
hal wrote:i am not sure exactly what a 'ribbed' fibral mop looks like could you please post a photo of it?
You only use the 'ribbed' mops to deal with 'finned' or grooved surfaces.
'Ribbed' is my word: it means a mop made up of 3 or 4 seperate fibral discs, in 2 different diameters, laminated together into one wheel.
The larger diameter 'discs' clean the bottom of the groove while the smaller diameter items clean the crown.
Don't have a pic - but hope that helps!
For most operations you'd use a regular mop, comprising 3 or 4 'discs' of the same diameter, laminated together.
You can use these either mounted on an adapted bench grinder, or on an arbor mounted in an electric drill. I think it's worth investing in the bench grinder option - it's easier to hold the pieces to be worked on than the drill!
Visit PERFECT POLISHING website - they're my supplier. Other fibral mop suppliers are available.
Steve S
#29 PostAuthor: Steve S » Tue Dec 02, 2008 10:35 am
MaineKZ, Parts prepared like a true proffessional..............I applaud you! top job keep the pictures coming :D
hillbilly
#30 PostAuthor: hillbilly » Tue Dec 02, 2008 2:09 pm
my frame number is 10942 ,only 700 apart. :lol: :lol: 73 4.
Users browsing this forum: Bing [Bot] and 7 guests
