gearing
brian 450
gearing
#1 PostAuthor: brian 450 » Wed Nov 12, 2008 3:55 pm
Hi can any one tell me what size rear sprocket i need for my Z1000? I have got a 17'' rear wheel and a 17 tooth front sprocket.
london calling
#2 PostAuthor: london calling » Wed Nov 12, 2008 5:38 pm
17 teeth on the front seems larger than normal :?:
Jack
#3 PostAuthor: Rich » Wed Nov 12, 2008 6:28 pm
What size chain are you running?
brian 450
#4 PostAuthor: brian 450 » Wed Nov 12, 2008 7:34 pm
530 chain, i got got off set sprocket from dibben thats the size he said i need they do 16, 17 ,18 tooth
#5 PostAuthor: Rich » Wed Nov 12, 2008 10:19 pm
std is 15:33 with 630 chain, to replicate that you need a 37 or 38 rear sprocket depending on tyre size maybe a 35 to 39. Odd numbers even the wear out better. What size is your tyre?
brian 450
#6 PostAuthor: brian 450 » Thu Nov 13, 2008 9:06 am
hi, its a 190/50/17
#7 PostAuthor: Rich » Thu Nov 13, 2008 6:47 pm
37 rear will give 70 at 4500 rpm.
brian 450
#8 PostAuthor: brian 450 » Thu Nov 13, 2008 6:52 pm
so do i fit 37 rear?
#9 PostAuthor: Rich » Thu Nov 13, 2008 7:09 pm
That's up to you, std gearing gives 70 at 4200. Your tyre circumference is only 3mm down on my 160, so if you have the ponies to push that rubber around you may want to go higher geared, if you don't you may need to go with lower gearing for better acceleration.
brian 450
#10 PostAuthor: brian 450 » Thu Nov 13, 2008 7:12 pm
Thanks Rich
brian 450
#11 PostAuthor: brian 450 » Sat Nov 15, 2008 7:07 pm
am i right in thinking if i get a 16 tooth front sprocket i would need a 40 rear, as i don't think i will fit a 37 on my hub?
#12 PostAuthor: Rich » Sun Nov 16, 2008 7:22 pm
18F 40R
