Wheel alignment
Wheel alignment
As you all know my Z suffered a rear end smack couple weeks ago, heard of many methods to check wheel alignment but what is the best way, apart from tearing the whole thing to bits and having the frame checked.
Long bit of timber or 4 x 2 box section steel raised off the floor a little and pushed up against the bead of the rear tyre.
You can then see how it lines up against the front wheel with the bars straight !
Not very scientific but surprisingly quite accurate.
Asphalt Cowboy
Same method as above but get yourself down to your local B&Q or homebase and buy a couple of lenghts of extruded aluminium ( sort of thing used for runners on sliding wardrobe doors) these should be dead straight when you buy them and will stay straight if stored carefully out of harms way for the next time some nob knocks you off.
- Geoff Meager
- ZedHead
TLC is right ... but while you have the lengths of straight material in line with the wheels ... put a length of tubing in the top yoke With a plum line on each end .... and take a front & rear view of the bike on a level surface
Any serious problem will stand out like sore thumb
Then it will have to be sorted
