1975 a4 misfire between 2-4k all gears.Tried following.
Coils.Leads.points,Plugs,condensors,Timing static and dynamic,carbs are spotless jetted correctly floats etc all correct height,new rubbers airbox to carbs using old carbs to head rubbers but seem good and no leaks when spray wd40 around when running.Bike starts on the button and revs cleanly on stand only breaks up under load 2-4 k over 4k ok.plenty of fuel getting through tank vent is clear.Have also balanced carbs and pulling same vacumn all 4 carbs,compression test shows no diff between cylinders,exhaust is new with new head collet seals.Only thing i can think of to check is valve clearances!!!!! is that likely?as have always thought bad starting would be a symptom of this..........
