Can anyone let me know if all the carbs on the z1a were the same as the z1, ie big nut on the bottom of the float bowl. Mine is a late z1a but it has the screw type drain plug on the side off the float bowls,
cheers,
peter
z1a carbs, poss wrong ones.
RE Z1A CARBS
HI' Z1A CARBS ARE NOT THE SAME AS Z1 MICKY HESSE BOOK SHOWS SCREW TYPE AS YOU HAVE.
The earlier Z1As had the same type of float bowl as the Z1,have a look at this section on Jeffs site http://www.z1enterprises.com/reference/ ... guide.aspx
- DogsbolloxofZ1B
Z1A carbs were the same as z1 but changed part way through production. So yes some had the bolts in the float bowl others appear like z1B style, however, if you take a look at where the main jet screws into the body you'll notice two holes for the starter jet, as per z1 only one of which is tapped, this was removed on the Z1B. I could write a book..
Mike
Mike
- DogsbolloxofZ1B
