rec/reg
sweptail
rec/reg
#1 PostAuthor: sweptail » Mon Sep 29, 2008 7:59 pm
:) can anyone tell me if this is the right rec/reg for a z900a4. I want to update when my standard ones pack in. First attempt at photo so bear with me.
hope this works. 3yellow wires, 1 black,1red, 1 green
Tc
sweptail
#2 PostAuthor: sweptail » Mon Sep 29, 2008 8:01 pm
oops! didnt work. I`ll try again. tommy
Steve Cooke
Reg./Rec.
#3 PostAuthor: Steve Cooke » Tue Sep 30, 2008 5:49 am
Here goes Tommy,
MaineKZ
#4 PostAuthor: MaineKZ » Tue Sep 30, 2008 7:48 am
All seems to be going well then :D
There was a thread not long ago about an aftermarket R/R unit suitable for most if not all Zeds.
Big Fluff
Re: rec/reg
#5 PostAuthor: Big Fluff » Tue Sep 30, 2008 12:29 pm
sweptail wrote::) can anyone tell me if this is the right rec/reg for a z900a4. I want to update when my standard ones pack in. First attempt at photo so bear with me.
Tc
Tommy - Without even seeing a pic I can tell that you have a H**** reg/rec unit there. 3 x Yellow to alternator, Red to + live, Black to Ign (switched live) and Green to earth.
Whilst this may work to begin with, boiled batteries and bolloxed windings may result.!! Be warned - I've been wiring bikes for over 25 years and seen this many times :??
I suggest you buy what you need direct from Electrex http://www.electrexworld.co.uk/
They do the individual 'standard' regulator, rectifier, or a combined unit if you so wish. Don't get stuck at the roadside, at just £45 for a heavy duty combined unit, it may well be worth while in the long run.
phil churchett
#6 PostAuthor: phil churchett » Tue Sep 30, 2008 3:36 pm
Tommy, i've got one of the regulators from Electrexworld on my A4. It's been on about 10 years. Works fine.
You will need to check, but i seem to remember they are supplied with bullet connectors, you need to specify if you want the block connector.
Steve Cooke
#7 PostAuthor: Steve Cooke » Tue Sep 30, 2008 3:50 pm
Now why on earth did photobucket delete three pictures of a Reg./Rec. they were on here this morning when I first put them on, could it be because the wires were stripped. :lol:
Garn 1
#8 PostAuthor: Garn 1 » Wed Oct 01, 2008 11:25 am
Steven, loss of photobucket snaps, could be due to the sites overloaded (slow) state.
Back to the topic.... Sweeptail, I would use pretty well any regulator/rectifier in a finned case with 6 wires. I usually use a reg/rec unit off a ZXR 650. I have had many factory single regulators give up, boil the battery and burn the coils. To me, the Rectifier/regulator fit is mandatory for Z1's, Z900 to Z1000-A1. I check them by reading the voltage across the terminals of a fully charged battery at about 3500 RPM to see that they do not exceed 14.5 volts.
RegardZ
02GF74
#9 PostAuthor: 02GF74 » Wed Oct 01, 2008 12:19 pm
Garn 1 wrote:Steven, loss of photobucket snaps, could be due to the I check them by reading the voltage across the terminals of a fully charged battery at about 3500 RPM to see that they do not exceed 14.5 volts.
I agree - despite the Haynes manual saying 16 V is fine - in the test regulator section.
sweptail
#10 PostAuthor: sweptail » Sat Oct 04, 2008 11:10 am
sweptail
#11 PostAuthor: sweptail » Sat Oct 04, 2008 11:13 am
sweptail
#12 PostAuthor: sweptail » Sat Oct 04, 2008 11:13 am
bollock. HELP
sweptail
#13 PostAuthor: sweptail » Sat Oct 04, 2008 11:15 am
sweptail
#14 PostAuthor: sweptail » Sat Oct 04, 2008 11:31 am
[img][img]http://i449.photobucket.com/albums/qq217/sweptail/recreg008.jpg[/img][/img]
sweptail
#15 PostAuthor: sweptail » Sat Oct 04, 2008 11:34 am
result. Perseverance and ignorance paid off. :shock:
Users browsing this forum: Bing [Bot] and 11 guests
