Valve cover gaskets
cra-z1
Valve cover gaskets
Trying to reduce the seepage at the valve cover gasket. Seems like oil is wicking through the paper gasket. I am using an aftermarket gasket and have billet end caps. Not sure who made the gasket, but it was blue in color. Does any one have a concences on quality? OEM vs aftermarket. Which seals better? What have people done to reduce the wicking affect?
cra-z1
I have already machined a groove in the billet end covers. I use copper high temp silicon in the groove. The oil is just wicking around the entire gasket. Not much but enough to leave a noticable trace of oil on the head and cover. Some places I get a little run down the head after a two hundred mile ride. I would just like to have as little as possible to wipe up. I know my Z1's in the 70's had the same type of wicking, but back then I didn't worry to much about it.
