clutch slippage
clutch slippage
Hi Lads,since I've had me bike back on the road I've noticed a bit of clutch slippage mainly when on the power,I had a bit of play with the adjustments but it still slips,so I pulled the clutch out for a bit of look,the plates look ok visually but I havnt messured them yet but I did messure the springs,my manual says that the free length of the springs should be 33.8mm and the wear limit should be 32.3mm yet all the springs messure about 35mm ,is it possible the springs could be an aftermarket item? surely the springs would get smaller not longer,any ideas on this ?cheers Ken.
phil churchett
phil churchett
You can get a new set of friction plates for £20 on eBay....
For that amount may be worth a try... coz if its been run with synthetic oil, it may have contaminated the plates & they cannot be cleaned..
If the F/plates are old, they can deteriorate and thats the end of them.
Springs are quite cheap too..... so a new std set is a good investment.
The needle roller mushrooms are good... easy to fit & only about £20
I've got one in me Zed with an MRE 'lock-up' clutch and its performed great for the last year & several 1/8 & 1/4 mile runs
I had a bit of clutch slip a while back, so forked out £100 on eBay for an the lock-up.... that way you can keep the softer springs & light action, but have a non-slip clutch
finally got to go for a ride after fitting the APE clutch plates and the first ride the clutch was slipping like you wouldnt belive so I backed off the adjuster at the pushrod and all seems fine now though it still seems to be to heavy,but that could be down to having clipons and putting to much drag on the cable maybe.Cheers Ken.
