Z650 Drum brake locking up
evurr
#1 PostAuthor: evurr » Tue Aug 26, 2008 12:06 pm
Before I put the Z650 into store one of the problems I used to have was the rear drum break locking up.... not every time but sometimes i would put my foot on the brake and it would send me skidding.
Blokie says the drum is oval but my dad's not convinced. Are there any other reasons why this would happen?
Has anyone else experienced it?
Cheers guys
Image Bird on a Bike Image
zedtwo
#2 PostAuthor: zedtwo » Tue Aug 26, 2008 12:20 pm
Have you checked condition of brake shoes ? Another possiblity is lack of grease on cams that operate shoes .
mikey
#3 PostAuthor: mikey » Tue Aug 26, 2008 12:32 pm
Could be everything just wants unseizing, had similiar problem on my daily scoot/winter hack (gs 650) and it was the rear brake pedal pivot/cam sticking where it passes through the frame.
Hobbo
BRAKES
#4 PostAuthor: Hobbo » Tue Aug 26, 2008 1:46 pm
Evurr
Had this problem myself removed the back wheel and all the brake linings just fell out put new shoes in but wheel did need skimming as well
Good luck
PHIL
phil churchett
#5 PostAuthor: phil churchett » Tue Aug 26, 2008 5:53 pm
Check everything the others have listed above and make sure you are happy with it.
Hopefully the drum hasn't gone oval and it is just the cam sticking in the brake plate. On the 900's there is a seal that fits over the cam, [where it pushes through the brake plate], to stop road grime seizing the cam up.
Let us know how you get on.
RALPHARAMA
#6 PostAuthor: RALPHARAMA » Tue Aug 26, 2008 10:50 pm
The only REAL way to be sure if the drum is oval is to take the braking plate out with the shoes n stuff, and remount the wheel back in the swing arm and clamp a DTI (Dial Test Indicator) to something immovable eg the swing arm and use that to check the concentricity of the braking surface of the drum. Obviously all the moving parts of the braking system should be proved to be free as a matter of course.
If yer old man hasn't got a DTI and allied stuff for mounting it, you want to chat up a local engineer. I'd happily help out but I think you might find someone closer to home ... besides I've still gotta perform the impossible and get Tricky Micky's bike ready for the South West rally :shock:
You and your betrothed coming? ZRX is perfectly acceptable medium to arrive :wink:
Ralph Ferrand
zedrider
#7 PostAuthor: zedrider » Tue Aug 26, 2008 11:06 pm
lose lineing on shoe seams the most likley .
zed
evurr
#8 PostAuthor: evurr » Wed Aug 27, 2008 9:17 am
cheers guys... I don't think this will be on the table for a little while but I'll pass all the info on to dad and see what we can find.
I think he knows a guy who can skim the drum as the wheel won't fit on his lathe.... but we'll check all the other options first as they sound cheaper and easier!!
Frame is at powder coaters now so hopefully it won't be long before the rebuild!!!
