Basically, all that was on my filter bolt is the O-ring, then the spring, followed by the oil filter element and that's it
I'm sure there is something missing.....
Many thanks, Will
Rich wrote:Upto and including Mk2s - you are missing the washer that goes on top of the spring and stops it from biting into the filter rubber. Check your filter to see if it is stuck to it.
