What is the smallest amperage battery I can use to run a Zed with no electric start and no lights?
The charging system will still be in place.
What do total loss systems use?
Gus
Smallest battery to run a Zed with no electric start.
"Set the GRINDER on it"
Big Glenn
Big Glenn
I would have thought the charging circuit would put out enough to run the bike.
Does anybody have any output figures?
Maybe a small battery would help stabilise the system using the sense wire from the rec/reg unit but I'm only guessing.
Who built the Gardner Moriwaki replica, doesn't he run a total loss system using a battery from a model shop or something similar?
FER wrote:Boyer do a power box which doesn't need a battery . Reg' and rect' built in . Got one on my lawson and it works ok .
fer
Do you run the Lawson without a battery fitted Fer?
How much are they?
I see on the Boyer website they mention a capacitor in the power box.
That is sort of what I meant about using a small battery to stabilise the system.
I'll try and give them a ring tomorrow.
The technical Guy at Boyer doesn't think that kicking the bike over will spin the alternator fast enough to generate enough power to fire the engine( I think he said around 300rpm).
Although a push start does work for race bikes.
He thinks maybe a 3Amp battery with their Power Box might just do the trick.
So I might as well just try a small Amperage battery with what I've got.
The Power Boxes are £78 delivered.
