now the carbs are out of the way, I plan to remove the breather clean it up and do some compulsory behvaiour polishing.
Is this a good idea - i.e. am I likely to destroy the gasket removing it?
What am I likely to find inside it? a mesh with an oily mess?
engine breather
- RALPHARAMA
I memory serves me right I think it has an 'o' ring seal. Inside there are some odd baffle things. Not a hard job to take apart.
Ralph Ferrand
yep big o-ring on the base and smaller one under the bolt.
was surprised how nearly spotless it was inside - car breathers have usually been full of black crud.
a quick wipe inside, going over with some 1200 wet'n'dry and painting the bolt head silver has it looking spick and span (whatever that means!).
