Is it a good idea to fit stainless steel screws to hold the carb fuel bowl and top covers?
And what is the prefered type: cross head (like original), cap head or button head?
stainless steel carb screws
- RALPHARAMA
I used ickle stainless cap screws on mine. From a practical perspective they're the donkeys, but if you're anal about originality then you'll be wanting the standard zinc plated philips screws made from cheese. Here's mine:
By the way if they're grubby try cleaning them with Jizer - that all I used on mine - soaked them and then scrubbed them with CB's toothbrush. Tedious and time consuming, but at least you know the buggers a properly clean
Ralph Ferrand
oooh ... those are very clean and shiny - don't give me ideas as I'm trying to resist polishing and stuff.
the cap heads you have - do they have spring washer fitted?
I don't see the flat plate that joins up the 4 carbs - did the early Zeds not have this?
Been thinking of making this from stainless but a quick spray up in silver has to do for the now.
- RALPHARAMA
I did take a good portion of a day to clean and polish the cards, but I'm glad I did them - a winter job me thinks
I did use stainless spring washers. Don't want 'em undoing themselves
Ralph Ferrand
bike help
vduk wrote:By the way if they're grubby try cleaning them with Jizer - that all I used on mine - soaked them and then scrubbed them with CB's toothbrush. Tedious and time consuming, but at least you know the buggers a properly clean
Just noticed this thread - you scrubbed them with what???
Marion
(PUM)
1976 Z900 A4, 1978 Z650, 2010 Triumph Street Triple
(PUM)
Steve Cooke
- RALPHARAMA
I keep forgetting she's joined us on the dark side.
Hopefully she'll let me off with a mild beating as I changed her chain and sprockets
Ohh I can't wait
Ralph Ferrand
