piston sizes
michael thomas
piston sizes
#1 PostAuthor: michael thomas » Sat Jun 28, 2008 9:25 pm
I have just started stripping the cylinder head and cylinders of my z1 ltd, i have noticed that apart from the arrow on the piston crown there is no size ie is it standard or is it an oversize or do you take it that if no size on top its a standard
Iain marshall
#2 PostAuthor: Iain marshall » Sat Jun 28, 2008 10:22 pm
If it has two very small cut outs on the crown and doesn't have 0.5 or similar stamped oi it its more than likely Standard(70mm)
#3 PostAuthor: Rich » Sun Jun 29, 2008 6:55 pm
no size usually means it's std
michael thomas
#4 PostAuthor: michael thomas » Sun Jun 29, 2008 6:56 pm
Thanks for that,been in the garage all morning and have taken the block off pistons look fine with no signs of blow past ,but how to check? also droped one of the rubber cam chain roller spacers into engine (oh joy) managed to retrive by draining oil, is there an easy way to clean old gaskets off
#5 PostAuthor: Pigford » Sun Jun 29, 2008 8:41 pm
Mike, the only way of de-gasketting ( :?: ) is time & patience :wink:
I use a stanley blade and just go carefully :??
I have tried those gasket softener sprays before, but never had much success with them :cry:
london calling
#6 PostAuthor: london calling » Sun Jun 29, 2008 9:32 pm
Piggy's right,there's no quick way.
Look out for a scrapper that takes a double sided razor blade on handle,my mate's got a Snap-On one that I borrow,but I'm sure other tool manufacturers do 'em :wink:
Jack
RALPHARAMA
#7 PostAuthor: RALPHARAMA » Sun Jun 29, 2008 10:30 pm
NO :(
Ralph Ferrand
Dark Skies
#8 PostAuthor: Dark Skies » Sun Jun 29, 2008 11:36 pm
Nail polish remover (acetone) goes a long way to softening up the gasket material for removal (using a stanley blade).
KZ1000-M1 CSR
london calling
#9 PostAuthor: london calling » Mon Jun 30, 2008 5:43 am
Draper tools do a similair thing,part number 65543,retail is £11.
Jack
michael thomas
#10 PostAuthor: michael thomas » Mon Jun 30, 2008 3:11 pm
Thank for that, used a sharp scraper designed for removing paint from windows and spent many happy hours scraping :evil:
