Just installed dyna coils,wires and the ignition pick up. Zed is running real good. However you can hear the coils,and it is rather loud. At first I thought is was cam chain so I adjusted not once but twice. finally found the tat tat tat niose is the coils. Is this normal sound from coils???
cheers
gregz
noisy dyna coils
noisy dyna coils
Z1
1965 Corvette
1965 Corvette
- rickman CRR
Steve Cooke
I found my problem. The spacers(hardware store) are two thick in diameter. When fitted loose they fit good but when tightning the coils to the frame they seemed to draw in a little bit and just make contact with the screw for the power wire. I replaced them with stock spacers but I had to use some extra washers so coil does not make contact with frame.
No more noise. If you are still running points I would highly recomend the dyna set up. With the denso plugs and the eletronic ign. Zed runs good !
gregz
gregz
Z1
1965 Corvette
1965 Corvette
