Swinging arm bush replacement
1340fxd
#1 PostAuthor: 1340fxd » Sun Jun 22, 2008 8:23 am
I want to replace the swinging arm bushes on my KZ1000 A2 - is this one of those jobs you wish you never started and are there any tips for a first timer please?
Do I fit just new bushes or the shaft as well and are these available from Z Power? :??
Dear Santa, please can I have...
#2 PostAuthor: Pigford » Sun Jun 22, 2008 6:54 pm
:shock: :??
Bit of a lottery this one.
#1 do they really need doing (any wear/slack) :?:
#2 remove swingarm & if the old bushes won't budge.... PANIC :!:
Good luck :wink:
Tall_order
#3 PostAuthor: Tall_order » Sun Jun 22, 2008 9:26 pm
I changed the swing arm on mine for a GPZ900 ally one, had the new bushes (yes, they lied to me when they said it was a direct fit!) made in phosphor bronze. Cost a bit but nice job. Worth considering?
RALPHARAMA
#4 PostAuthor: RALPHARAMA » Sun Jun 22, 2008 10:03 pm
'less I'm losing the plot aren't the bearings needle rollers in the standard zed thou swinging arm? I'm sure mine were cos I replaced 'em
Ralph Ferrand
Tall_order
#5 PostAuthor: Tall_order » Sun Jun 22, 2008 10:13 pm
vduk wrote:'less I'm losing the plot aren't the bearings needle rollers in the standard zed thou swinging arm? I'm sure mine were cos I replaced 'em
They are, yes :)
1340fxd
#6 PostAuthor: 1340fxd » Mon Jun 23, 2008 6:28 pm
Ah - some light!
Are you saying that the Z1 swinging arm bearings are bushes and b*ggers to remove while the Z1000 (mine's a 1978 A2) are needle rollers and a piece of cake to replace? Or am I getting confused now? :oops:
RALPHARAMA
#7 PostAuthor: RALPHARAMA » Mon Jun 23, 2008 6:50 pm
Haven't got a Z1, but I do have a Z1000A1 and that definitely has needle rollers. I can't remember the sizes of the top of my head, but if you measure the little buggers you can get new 'uns from a bearing supplier such as simplybearing.co.uk
They are caged and you won't be able to get 'em out in one piece. I can scan /copy the relevant part of the workshop manual if you like. They do need to be drifted out.
Ralph Ferrand
