1100 carb inlet rubbers/manifolds
cbxade
#1 PostAuthor: cbxade » Thu Jun 05, 2008 6:47 pm
Hi,i have an 1170 gpz motor in my zed and i have a very nice set of Mikuni 36mm smoothbores to go on but i need larger inlet rubbers.They need to be 42mm bore.If anyone knows what will fit or where to get them from that would be great
Ade
#2 PostAuthor: Pigford » Thu Jun 05, 2008 7:26 pm
Pretty sure www.z1enterprises.com do 'em :wink:
I thought the larger MKII/GPZ rubbers were about 40-42mm dia :??
cbxade
#3 PostAuthor: cbxade » Thu Jun 05, 2008 7:33 pm
Mmmm! I'll look into it
Ta very much
#4 PostAuthor: Pigford » Thu Jun 05, 2008 7:38 pm
Gus
#5 PostAuthor: Gus » Thu Jun 05, 2008 9:24 pm
I run a 1260 gpz motor with 36's and use stock 1100 inlets.
Debben do some but they won't fit the B1 without mod's see here near the bottom of the page
"Set the GRINDER on it"
big green bus
#6 PostAuthor: big green bus » Sat Jun 07, 2008 7:14 pm
zx6 ones fit strait on but they are about 20mm longer so if space is tight you may struggle but they fit 36's no bother and have carb balance take off,s too
