Cam End plugs - Cylinder Head rebuild
kiwiz
#1 PostAuthor: kiwiz » Mon Apr 24, 2006 10:02 pm
I have bought some new cam end plugs to fit but am concerned that they will be prone to oil leakage. I there any cunning scheme to ensure these things don't weep between the plugs and the cut outs in the head?
mikey
#2 PostAuthor: mikey » Mon Apr 24, 2006 10:10 pm
I put a light smear of
silicone gel instant gasket
over them but use clear looks neater.
Padders
#3 PostAuthor: Padders » Tue Apr 25, 2006 6:42 am
I am the same as you Mikey, a small dab wipe off excess and bob's your uncle.
Jon
#4 PostAuthor: Jon » Tue Apr 25, 2006 7:34 am
Yeah never had a problem neither!
#5 PostAuthor: Rich » Tue Apr 25, 2006 3:40 pm
Wipe the mating surfaces off with acetone (nail polish remover), slight smear of silicone RTV, put together, wait until dry before tightening cam cover down so they don't push out.
Alternatively buy some APE alloy ones and don't worry about them again.
#6 PostAuthor: Pigford » Tue Apr 25, 2006 6:34 pm
Ape end caps are good... only in blue tho'.. unless you polish them! They also need silicon or similar to seal. I always use em. I had to file them out a bit to fit me Z1A as they to tight to fit! Look much better than rubber things too!
hanskloss
#7 PostAuthor: hanskloss » Tue Apr 25, 2006 8:54 pm
Hi, on an old and hard set of rubber plugs I had to use silicone gasket just to keep them in place, than got a new set and these were tight fit , no silicone and no leaks either, finally I got APE alloy ones, all four are the same size but two fitted to one side had to be filed quite a lot as were too high,got mine polished too, good thing is that job has to be done once than silicone them in and should stay forever, agree with Pigford they do look quality
Users browsing this forum: Google [Bot] and 19 guests
