Z1R Advance Retard Unit Identification ?
Can anyone advise me as to what the number stamped on the advance retard unit for a 1978 Z1R is ?
The one I am using has "1009" stamped on it
I would be interested to know if this is the correct unit
Fanx
Gary
Fanx
Gary
Hello Mine is a Mk1 (Z1000D1) funny the other one i have is a "1003" unit but it runs like crap with it.
hmmm mysterious
Gary
hmmm mysterious
Gary
No it is running on electronic ignition from a MK2 Z1000
Right
Thanks too both of you for that, Im gonna have a fiddle swapping bits around.
Whilst it runs really well on the unit marked "1009" it wont run properly with standard size needles 5CN15 (too rich)
It will run well with needles 5DL31 from a Z1000 B1/B2 26mm carbs
Hmm more brain aching thinking
Thanks again
Gary
Thanks again
Gary
Right
I tried out my A/R unit with 1006 on it and there is not much difference to using the unit with 1009 on, the engine seemed a little flatter but not much
I am wondering if i should forget about using the standard Z1R needles and keep the ones i have from a set 26mm carbs in there and upping the main jets from 105 to 107.5.
The plugs are a light grey colour, so at least it is not fouling them up like it used to
any thoughts
Fanx
any thoughts
Fanx
DLs will give you a slightly richer bottom and leaner top to the needle range than CNs, The letters denote what taper they have (in this case dual taper) and the 5 in the "5DL" is the length code.
What needle jet is in them, std should be O1 or O3? You will need to drift them out and back in, you can use the emulsion tube as a press for replacement but you risk stripping the threads if you do and it is certainly not advisabe. Main Jet for the D1 should be 107.5 according to the manual. Are they 3 hole or 5 hole emulsion tube?
What voltage do you have at the coils?
If it runs well with the Dls make sure the plug colour is Ok at about 7K. and leave them in. Light grey is good
Hello Rich
thanks for your reply.
Here is what i have fitted in the carbs.
The needle jet is a new 258-01 (Keyster carb kit), the old needle jets were very worn by comparison
The pilot jet is a 15 (new)
The main jet is a 105 (recomended is 107.5)
The needle is a DL ( as it runs too rich on the CN type)
The emulsion tubes are new aswell, they are for the Z1R 28 mm carbs in that they have a rubber "O" ring seal near the top of them, i seem to remember them being 3 hole
I modified the coils so they run via a relay straight off the battery so they have full battery voltage across them
Does any of that set up give any clues?
Gary
Gary
Advanece Retard/Emulsion tubes
Hmm i treid uploading some pix of the tubes but i cant
Mine have two rows of two holes going along the length of them and two rows of 4 holes along the length of them
I bought these from Zpower a while ago as it was pointed out to me that the ones i had were not correct
Gary
Gary
