Big Fluff wrote:[However, case hardening is typically around .0014" (0.3mm) deep into the material. Now although I don't condone shim grinding, taking a couple of thou' (0.5mm) off each end isn't going to hurt.
Missing 0?
chrisNI wrote:Big Fluff wrote:[However, case hardening is typically around .0014" (0.3mm) deep into the material. Now although I don't condone shim grinding, taking a couple of thou' (0.5mm) off each end isn't going to hurt.
Missing 0?
