Looks like I will be riding a Z900 A4 this year after doing a deal against the Harris. However it has a set of bright red Mazzers on it! Having been on monoshocked bikes/specials for the last 8 years I am a bit out of touch on twin shockers.
A, Can you still but Ohlins for the Z900 and if so how much and where.
B, Can you recommend an alternative decent adjustable shock.
Also whilst I am on can the grab rail for the Z1A be used on the Z900. I know the indicators are supposed to mount to the Grab Rail but are the mounts on the frame still the same as the Z1A.
Cheers for now Ian.
Z900 A4 REAR SHOCKS WHICH ONES - Also rear grab rail question
- london calling
Ian,go to the HARRIS website and follow the Ohlins link.
Harris are the U.K importers of Ohlins so all the spec. is on there.I think the basic piggy back Ohlins are about ?395 and the hi/lo speed damping models are ?600+ but i may be wrong.If you look in the back of Superbike magazine there are regional Ohlins centres such as KAIS and Mick Gardner Racing.I think Mick Gardner is the nearest one to you but all the info is available on the Harris website.
- london calling
Iain marshall
or what about Ikons there the same as the Koni dial a rides,not too sure who sells them,heres there web site http://www.ikonsuspension.com/
