Brain teaser (sparx)
Ed Z1-R
#1 PostAuthor: Ed Z1-R » Thu May 15, 2008 11:35 pm
ok, rewiring a Z650 C2.
All going hunky dory until i hit the regulator rectifier.
Now i dont know if the RR is o.e.(some ive seen are 2 phase and some 3 phase) but heres the dilema.
Most 650 are 3 phase but this is 2 phase(ie 2 yellow wires not 3)
Nearly all RR have the yellows and wires for:- Earth(black/yellow), main feed off battery(white/red) and one for regulated feed.(brown).
there are only 2 yellow wires ,BUT NO BROWN WIRE.
So how does this work :idea:
As in there is no regulated feed, where does the regulated volatage for the brown wire takes its juice from???????????
Is it from internal connections in the ignition switch?
So i is stumped on this,any help appreciated (no i dont have wiring diagram just working from a Z1-R as most K are wired the same)
THANX. :wink:
Dark Skies
#2 PostAuthor: Dark Skies » Fri May 16, 2008 12:22 am
Is this any help?
KZ1000-M1 CSR
Ed Z1-R
#3 PostAuthor: Ed Z1-R » Fri May 16, 2008 9:18 am
Dark skies, Many thanx for that will print this off to peruse and study.
Should make progress now Woohoo!!!!!!!1
#4 PostAuthor: Pigford » Fri May 16, 2008 7:13 pm
Ed, I got a spare (Z650 I think 95% sure) RR if you need it :wink:
Ed Z1-R
#5 PostAuthor: Ed Z1-R » Fri May 16, 2008 11:47 pm
Cheers Pigforatu :wink:
