Having finished a re wire, of the above.
Last night. I started the bike. It purred.
Sounded gorgeous, it was running for about 5 - 10 minutes.
Revs being kept down, as it has had a full engine re build with a reconditioned cylinder head, with ported head, new valve springs, guides, seals etc.
The rev counter stopped working and then there was a nasty rattling coming from the top end.
On taking off the rocker cover, the Tacho drive gear has snapped, sheared off part of the gears from the exhaust camsaft.
First thoughts are I will have to take off the head, barrels and pistons. Strip, clean and re build head. Check main bearings, check bottom end for bits of metal. Maybe take the sump off.
Second thought, I may have to do a full engine strip down ?
Any thoughts ?
