Mikuni flatsides
Murph
Mikuni flatsides
#1 PostAuthor: Murph » Sun May 11, 2008 8:03 pm
For no apparent reason my flatsides have begun leaking from the overflow
pipes this just started today as i was working on something else on the bike its just a small drip but even with the fuel turned off its still leaking .
havent taken them off yet (could it just be shit holding them open! )
but was wondering does anybody have any ideas :?:
Z9A4, Z1170R, ZZR1100
debben1
#2 PostAuthor: debben1 » Mon May 12, 2008 12:23 am
Hello Murph, Yes, the float valve is not shutting the fuel off, you could try squirting a little wd40 down the fuel lines, sometimes works, is the bike left on the sidestand ? if the bike is parked upright on mainstand or paddock stand there is less chance of this problem. Regards, Steve
Murph
#3 PostAuthor: Murph » Mon May 12, 2008 9:32 am
Hi steve
yes the bike is on the side stand at night and i dont have a paddock stand for it as its a single sider at the rear end .
will try your tip tonight and thanks for the advice .
Murph
#4 PostAuthor: Pigford » Mon May 12, 2008 11:52 am
Why not put a packing piece (eg: a bit of wood) under the side stand, to keep it near vertical.... :wink:
Before anyone starts, make sure it can't fall over to the right tho' :roll: I have a small length (ooooh errrrr missus) of rope attached to the wall and it is hooked onto the right handlebar end as insurance :?? for this exact purpose :twisted:
Murph
#5 PostAuthor: Murph » Mon May 12, 2008 11:59 am
Might just do that pigford i.ve never had a bike with flatsides before so didn.t know they were prone to this .
After i posted my appeal last night it started pissing out of the over flows
so cant wait to get home from weork to do somthing about it .ie try steves tip :wink:
FER
Auld Heedyun
#6 PostAuthor: FER » Mon May 12, 2008 9:37 pm
Switch the fukin fuel tap off !
fer
Murph
#7 PostAuthor: Murph » Tue May 13, 2008 12:05 pm
Thanks for your helpful advice fer as i said in my first post ( THE FUEL TAP WAS OFF !) :roll: but it was emptying the bowls .!!
Anyway did as steve suggested last night and it seems to be fine will just have to get a stand for it .
Thanks again steve . :wink:
london calling
#8 PostAuthor: london calling » Tue May 13, 2008 1:35 pm
What about the stand that you put the front wheel into and keeps the bike upright.
Not sure who make's em,etc but they look pretty usefull :D
Jack
Murph
#9 PostAuthor: Murph » Wed May 14, 2008 9:13 am
Hi jack i think i know the one you mean its certainly an option
that i hadn.t thought of as the garage is a bit tight for space as it is .!
Thats unless any members have a single sided paddock stand that.s
going cheap . :?: :wink:
#10 PostAuthor: Rich » Sat May 24, 2008 2:48 pm
If the fuel tap was off and it was still pissing out then you need a better fuel tap. When I used to get bits of crap (usually from inline filters!!!) holding the valves open I used to run the bike with the fuel turned off and then when it had stalled turn the fuel back on which usually cleared it from the valves without having to take anything off.
#11 PostAuthor: Pigford » Sat May 24, 2008 4:37 pm
Rich, another good tip, you're not just a pretty face then mate :wink:
Big John
#12 PostAuthor: Big John » Sat May 24, 2008 9:05 pm
london calling wrote:What about the stand that you put the front wheel into and keeps the bike upright.
They are called a "Bike Grab" and are very useful think they are about £90 I've had one for a while and can fully recommend them.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
not too upright
#13 PostAuthor: Al » Sat May 24, 2008 9:45 pm
Carefull, my friend D***** parked his Z1300 on the sidestand on the raised car platform to the side of the house. Unknown to him he had got a nail in the tyre whilst out riding that day and came down in the morning to find the bike standing on it handlebars in the passageway next to the side door. Passageway was 2ft 6 wide and the bike fitted it exactly. Got a fork lift truck from the local timber yard to lift it vertically out.
Murph
#14 PostAuthor: Murph » Sun May 25, 2008 10:30 am
Good tip there rich the bike has a pingle tap but was sitting for years
so there may be crap floating around . the tank was off for a respray
recently so who knows whats in there although it was cleaned when off !! :wink:
