Assembled pistons & rings...... as these are second hand from a good source
A good way of tackling this delicate process is... (Wiseco)
1 - Fit one circlip in the piston. You'll have to work out which side is going to be easiest to fit the gudgeon pin (wrist pin) before you do this
2 - Now fit the oil rings, the wiggly bit first bthen the thin plain rings each side.
3 - Now fit the middle ring (N facing upwards).
4 - Fit top ring! Place ring gaps staggered so that none are in line.
5 - Push the gudgeon pin part way into the piston (opposite end that the circlip is in
6 - Fit circlip in other recess.
More soon....
