loom routing mk2
christiemk2
loom routing mk2
#1 PostAuthor: christiemk2 » Tue Apr 22, 2008 9:26 pm
can anyone help with the proper routing of the wiring loom around the airbox on a mk2.
Im wanting to refit the box after several years withit on pods.
Doesnt seem to be enough room between the box and the frame mounted plate which carries the petrol tank rubber strap retainer.
should the loom go under this plate and down the back of the airbox?
Please help! :evil:
rickman CRR
#2 PostAuthor: rickman CRR » Tue Apr 22, 2008 10:02 pm
From the Klasmo web site. Its a Z1000A1 diagram but suggests loom runs down either the centre or the rear right handside frame rail. Maybe different on MK 2.
christiemk2
#3 PostAuthor: christiemk2 » Wed Apr 23, 2008 8:02 pm
rickman CRR wrote:From the Klasmo web site. Its a Z1000A1 diagram but suggests loom runs down either the centre or the rear right handside frame rail. Maybe different on MK 2.
cheers mate, will get back to the shed and give it another go
#4 PostAuthor: paul doran » Fri Apr 25, 2008 1:22 pm
the Klasmo description is correct
loom's goes down righthandside
