big green bus wrote:hi sorry i have not posted pic,s of the TLR swing arm i cannot find the lead for my digi cami will post it when i find it, but you lot have made comments on the state of my shed before, it may be a while.
big green bus wrote:you will need to grind part of the foot rest mounts as the arm will touch
big green bus wrote:it is not the bracing on the busa arm, it is the offset of the arm for the chain run. if you turn it upside down the offset is on the wrong side and too far over so the wheel will not line up. i have a busa arm and will take a pic to show you them both together. the tlr arm is the easier option but you may find a way around the problems with the busa arm. gsxr 600 srad arms fit straight in and are only £40. the earlystock boy use them.
