Carburator intake
CJE
Carburator intake
#1 PostAuthor: CJE » Mon Apr 14, 2008 6:28 pm
Hi, i have ordered a set of 33mm mikuni's and would like some information on the intake rubbers. the bike came with larger intake rubbers than standard and they don't have the pipe for balancing. Is this normal for after market intake's? Also the rubber has gone a bit on the brittle side so i will be looking at replacing them, any ideas where i can get over sized intakes? Thanks
#2 PostAuthor: Pigford » Mon Apr 14, 2008 6:36 pm
CJ, try your new mate... Jeff at Z1Enterprises... :wink:
I think he does 'em cheap - about 40mm diameter, and they don't usually have take offs :??
PJones
pics
#3 PostAuthor: PJones » Mon Apr 14, 2008 8:31 pm
Hi clint I have sent some pics
cheers
pj
WHO NEEDS DRUG'S
Iain marshall
#4 PostAuthor: Iain marshall » Mon Apr 14, 2008 8:49 pm
CJE heres one way round the no take offs on the larger intake rubbers,havent tried it myself but looks like hes drilled the hole to take the vac pipe then just screwed in a cap screw.The carbs are 38s :shock:
#5 PostAuthor: Rich » Tue Apr 15, 2008 5:24 pm
GPZ1100 intakes. Just set the slides by sight and you'll probably be near enough.
