Will Z1000 Ltd 1980 calipers fit my Z1000A2
Ian, got 2 LTD's (B2's) at the moment, according to the Z-Power parts book the front calipers are the same on the A1's and B1's. The A2's and B2's have a different part number but I'm pretty sure the fork legs can be swapped around to suit.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
- paul doran
Rich wrote:Piggy you're guessing again! I don't know how you ever got those spanners but I hope no-one followed you advice !!!!
STs had forward mounted axle, Mk2s "normal" forks and Ian will be making up mounting plates if he wants to use those calipers.
rich has your measure right enough Piglet your a bluffer or should that be an old duffer
